Is there a way to convert a Quotation to a Sales Order in Standard AX functionality?
Or will some customization be needed for the same.
Also, I would like to know how to set up the Sales quotation Workflow in AX, post which after the confirmation of the Quotation I would want it converted to a Sales Order.
Is there some way to achieve the same in AX standard functionality?
It’s a standard feature of AX to convert quotation to SO. Try confirming a quotation, you will see the SO created automatically. No configurations required.
By default, workflow configuration is not available for quotation, you would need to approach your developer.
