Hi … the bits below I have cut and paste from notes I made myself about 18 months ago, I hope they are useful to you and make sense (and indeed accurate)
If not, perhaps send me yours when you work it out …
Regards
Martin
Avg. issue per lead time:
This is calculated either by the Avg. issues per month divided by 30 days, hard coded (default number of days) or if the ‘working days’ is checked on the lead time (on the item record, item coverage) then it uses a hard coded method of 5/7ths (30 / 7 * 5) = 21.4286
Safety stock calculation using standard deviation method:
{1} calculate the monthly sales for the period and averaged
May
June
July
Aug
Sept
Oct
Nov
Dec
Jan
Feb
March
April
Total
Average issue
0
2
0
0
0
10
0
0
18
4
0
0
34
34/12 = 2.8333
{2} calculate the monthly std. deviation
0
2
0
0
0
10
0
0
18
4
0
0
Monthly Sales
-2.8333
-2.833
-2.833
-2.833
-2.833
-2.833
-2.833
-2.833
-2.833
-2.833
-2.833
-2.833
minus [-]Average issues,
Then (sqr ) c2
8.025889
0.693889
8.025889
8.025889
8.025889
51.365889
8.025889
8.025889
230.037889
1.361889
8.025889
8.025889
=347.666668/12
28.97223
Ö28.97223
= 5.38
This is the monthly std. deviation
{3} lead time calculation
For 1 day this is 1/30 = 0.0333 Ö = 0.182574
{4} Minimum quantity to order
Safety factor (see service level percentages) x monthly std. deviation x lead time
4 x 5.38 = 21.52 x 0.182574 = 3.928992 (rounded to 4, see UOM number of places to round)
Safety stock calculation using average monthly issues and factoring
{1A} Calculate the average monthly issues (same as above) = 2.8333
{2A} Then (if not already known) calculate the average daily issues for the lead time 2.8333/30 = 0.0944
{3A) Proposal calculation
Ave. issue per lead time in days x factor used for multiplying x (at least 1 days lead time otherwise zero will be ordered)
0.0944 x 10 = 0.944 x 1 = 0.944 rounded up to 1
