runtime email settings in AX 2009
Hello,
I am using AX2009 through remote access. I am sending email through code. I have done email parameter settings and written code with sysmailer. This is working fine. Now I want use this email parameter settings runtime. Like if company is “A” use type A email parameter settings and company is “B” then user type B email parameter settings.
can any one help me?
\Data Dictionary\Tables\SysEmailParameters is a shared table, you can change it to store the data per company. Set saveDataPerComany to Yes. But this change should need a proper testing on the existing functionality(related to Email), Example: Sending a document/Report by mail
Hi Kranthi,
thanks for your reply!
