Running non SSRS report in batch in AX 2012
I am having issues running a report I wrote that was upgraded from AX 2009 to AX 2012. I can run it fine if i run it directly from my client (both to screen and print), but if i select it to run in batch then it stays on the batch queue with a status of executing. If i look at the tasks then the run location is being set to "Client"which surely should be set to “Server”
If i run a std AX2012 report then that works fine so its not an issue with the batch group or server configuration as set both to use the same batch group.
Only thing I can think of is that my report is not SSRS and std reports is SSRS.
Any ideas as its driving me mad and need to get a fix asap ???
