if (custTable.PaymTermId)//always execute for mandatory
while select InvoiceDate from cust order by cust.InvoiceDate desc where cust.OrderAccount == custTable.AccountNum
i++;
if(cust.InvoiceDate == datenull())
return true;
if(i==2)
// select InvoiceDate from cust order by cust.InvoiceDate desc where cust.OrderAccount == custTable.AccountNum;
if (cust.InvoiceDate )
a=cust.InvoiceDate;
what is wrong in this lines…
if i run these code in job its working, but in class(cust credit limit) i wrote one method called chkdate in tat its not working, if , date already existing means its working fine, if the date is empty means, its not working…
pls any one help me…
thanx in advance…
