Hi all! I want to run a SQL Job from NAVISION (by Job Scheduler). The possibility I found is this:ReturnCode := SHELL('osql.exe -S MyServer -E -d msdb -q "EXEC sp_start_job @job_name = [MySQLJob]" -c -b');
But … … if I use -q then the Command-Window is opened - and NAVISION waits until it is closed (modal) - but this window is not closed automatically when the SQL job finished, so NAVISION waits until someone manually closes it. … if I use -Q then the Command-Window is closed immediatly, the SQL job runs in the background - but NAVISION does not wait for it (non modal) What I need is, that the window is opened, NAVISION waits until the SQL job is finished (modal) and then the window should be closed automatically. How can I do this? Thanx in advance! Kind regards,
I’m not sure, but what about using a .bat file to run the osql.exe command. The contents of the batch file would be: osql.exe -S MyServer -E -d msdb -q "EXEC sp_start_job @job_name = [MySQLJob]" -c -b exit
Then call this batch file in Navision instead of osql.exe directly. The EXIT command should do the trick… I guess… [:I]
Hi Nelson! Thanks for your advice, but it did not solve the problem [V] it’s the same behaviour with a .bat or a SHELL …
This is what I do now: - Execute the sp_start_job via OSQL - Within a loop, I execute sp_help_job to get the current job-status - I write this status to a local file to be analyzed by the NAVISION program - If the status shows that the job is finished, I exit the loop and continue the processing … Well, that’s the “old” version (from yesterday evening [;)]) … the “new” way (from today) is quite similar, but using MS ADO to execute the statements and without using a file, as I can analyze the status now “online” … Regards,
… and of course I appreciate any different or better solution! [:P]
Have You read this: http://www.mbsonline.org/forum/topic.asp?TOPIC_ID=12693 /Lars
Hi Lars! Thank for the advice! The solutions discussed there seem to be very similar to my ADO solution now, this shows me that this might be the right way …
Hi Guys.
I’ve been reading this topic and have tried the first solution mentioned;
When I try to run this, Navision complains about the filename containing a character that cannot be used. I have just copied exactly what you posted - so what’s the problem?
BTW - My Nav version is UK v4 sp3 with a SQL back-end.
