hi guys
i want to know … in which situations to put the run on property server in class
hi guys
If your class is a runbasebatch extended class, you have to do it on server side, if you execute it on client or called from side, you’ll get an error
if your class execute a heavy process (not in batch job), it is better to execute on server side.
regards,
Thomas
you can set the run-on property to called from which will be common for both server side and client.
Thanks & Regards,
Britto John Bakar.A
