RTC Server Address Selection
How cai I clean the list of server addresses showned on RTC server selection window?
In the user’s configuration file for the RTC there is a key/value pair called URLHistory. You can remove the values there (not the whole line, just the string assigned to the value).
Ok, thanks, I needed to search on exact location of that file but your hint was very helpful.
