OK this is the error in the event viewer. I thought the error might say RTC instead of Classic as keyword of an error.
The user says when he/she tries to go in to any vendor card the RTC shutsdown but its not always. Tried to check on microsoft support site but there isnt any detail for this error. Please help. Thanks.
Type: System.ArgumentOutOfRangeException
Message:
Index must be within the bounds of the List.
Parameter name: index
ParamName: index
StackTrace:
at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
at System.Collections.Generic.List`1.Insert(Int32 index, T item)
at Microsoft.Dynamics.Framework.UI.VirtualRows.InsertWithoutValidation(Int32 index, RowEntry row, Boolean needsUpdateCall, Boolean needsUpdateCurrentRow)
at Microsoft.Dynamics.Framework.UI.BindingManager.AddToCollection(Int32 index, RowEntry rowEntry)
at Microsoft.Dynamics.Nav.Client.DataBinder.RecordLinksBindingManager.HandleNewRow(RowEntry rowEntry)
at Microsoft.Dynamics.Nav.Client.DataBinder.NavBindingManager.HandleNewRow(Bookmark bookmark)
at Microsoft.Dynamics.Nav.Client.DataBinder.NavBindingManager.UpdateRowCore(Bookmark bookmark, RowEntryChangeType rowEntryChangeType, Bookmark newBookmark, Object tag)
at Microsoft.Dynamics.Framework.UI.BindingManager.UpdateRow(Bookmark bookmark, RowEntryChangeType rowEntryChangeType, Bookmark newBookmark, Object tag)
at Microsoft.Dynamics.Framework.UI.BindingManagerBoundObjectConsumer.OnMessageAvailable(IMessage message)
at Microsoft.Dynamics.Framework.UI.ConsumerPort.MessageAvailable(IMessage message)
at Microsoft.Dynamics.Framework.UI.CommunicationChannel.SendConsumerMessage(IMessage message)
at Microsoft.Dynamics.Framework.UI.CommunicationChannel.ProcessMessages()
at Microsoft.Dynamics.Framework.UI.CommunicationBroker.HandleMessages()
at Microsoft.Dynamics.Framework.UI.WinForms.ClientSession.HandleMessages()
at Microsoft.Dynamics.Framework.UI.WinForms.ClientSession.Application_Idle(Object sender, EventArgs e)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Application.ThreadContext.System.Windows.Forms.UnsafeNativeMethods.IMsoComponent.FDoIdle(Int32 grfidlef)
at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.Run(ApplicationContext context)
at Microsoft.Dynamics.Nav.Client.Program.MainCore(String[] args)
at Microsoft.Dynamics.Nav.Client.Program.Main(String[] args)
Source: mscorlib
