RTC Connection Error
I had Nav 2009 R2 installed on my machine.
I am getting following error when i am trying to open RTC :
Microsoft Dynamics NAV
The Microsoft Dynamics NAV Server cannot connect the Change Listener to SQL Server because of the following error: A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: Named Pipes Provider, error: 40 - Could not open a connection to SQL Server)
OK
Please suggest me the solution
Abhishek
Have you searched for “cannot connect change listener”. This has been discussed a ton of times on all of the NAV forums. There are also instructions in the installation (in the NAV Classic Client Help Menu) for how to connect the change listener.
Thank Matt for reply,
My problem is resolved, I haven’t define the database Instance name in “CustomSetting.config” file.
T
how did u solve it…i couldn’t :frowning:
