Row definition -Export to a file--Error
I am trying to export the Row Definition from one company and then import in another company, so that i can save some time.
GL-Setup-Financial Statement-Row definition-- TEMPLATE --Export to a file.
I get an error message
“Row definition ‘Balance Sheet’ contains elements with fixed priority. Export canceled”
Any idea.
regards
TP
hey i just have a doubt in that sequence you gave! 'm trying to understand your query!
i have the financial statements only in reports! in setup i don have it! cn you tell me a bit clearly please!
I am not trying to export the report, as I mentioned I am trying to save my time by exporting the design of the row definition
The setup of the ROW DEFINITION is done here…
From here only we can export the Row definition to some file and then re-import to another Company.
This will save my time in designing
Please advice.
regards
TP
i get that you dont want to expor reports! what i asked in my previous post was where exactly is this finacial statements! are you doing this in MS Dynamics Nav? or in some other dynamics?
HI,
Of course in Ax 2009, you should be able to find in GL
regards
oh 'm sorry dear! i know only MS Dynamics Navision! thats why i asked first itself! sorry! i really wanted to help:)
we have same problem…
For some reason that I don’t reach to know, exportation can not be performed when in the structure there are items with types element or structure.
If a row definition in the template that is being exported has a value of or in the drop-down list, the export cannot proceed. Instead, you will receive an error message that indicates the row definition that has a fixed priority ( or rows).
a template row definition can only contain rows of type , , or .
As far as I know, this is AX default.
You can comment the code on LedgerRowDefExport class, run method and the export will be done succesfully. After that you could import the file into the other company
Otherwise you always have the option to create a new definition group with the AX tables involved on this form and export/import the data
