Client wants to have very lengthy descriptions for Routing Lines. If I want to increase the size of the Description field in Routing Line table, what other tables would have to be modified with this change? Does the Description field ever flow to any other table? TIA
Yes, this is a very big task to do. You could get the developer toolkit, do a where used and modify all other objects. But even then you won’t find it all. The easiest way is probably to add an additional big description field and add functionality around that field as you use it.
This “systemsolution” is a very well discussed problem. Here in the forum the meaning mostly is : DO NOT CHANGE STANDARD FIELDS use your own extendend fields
