Dear all,
Is ther any scope to difine the Route Path ( Routing sequence ) at the time of a Finished goods creation ??
Scenario
A = a Finished Good
B, C are the BOM component of the Item A.
B has two Routing Path
1. BR1
2. BR2
similarly C has also two Routing Path
1. CR1
2. CR2
I want that B and C choose their own Routing on demand at time of Production Order creation for the Item A.
How to do ??
You have to use the “version” granule. With this granule you can create several ‘versions’ of Routing as well as several ‘versions’ of BOM. For a single Item.
You have to select one ‘active version’.
The problem is you have to choose, the OP asks for the system to do this for them, presumably on a capacity based priority.
Hey Jaideep !!!
I know that a FINISHED GOOD ITEM or SEMI-FINISHED GOOD Item may have multiple version of BOM or ROUTING. [H]
But my query is different. [:@]
Can I define the final “ROUTE PATH” in the FINISHED GOOD Level ?
Not as standard no, as I understand your requirement.
