I am using navison Attain 3.60. When processing in general journals, navision is rounding off the amounts. i.e if I enter 3433.89, navision will record it as 3434.00 Problem is our client insist on using it correct to 2 decimal places. Is there a setting that needs to be done? cheers Sam
Hi Invoice rounding precision if you are referring to the amount, in the General Ledger Set-up If it is with a foreign currency, check the amount rounding precision against the currency. Coupled with this is the Amount Decimal places field that requires setting appropriately. There is also a unit amount rounding precision (hidden) in the general ledger set-up if you are referring to quantities.
