Dear Sir
I have created two Role
- One for Read the Item Master ( Form ID. 30) (also considered the required objects in this role)
- Two for Indirect Read permission to the Tabledata Item Ledger Entry table (Table ID. 32)
And assign these two roles to a user1. Now User1 can able to Open the Form ID 30.
If I remove the Role no. 2 then User1 can not able to open the Form ID 30.
Now I have created the same scenario again…for creation of Sales Order (SO)
I have created two Roles - One for Creation of Sales Order. Here I have considered the required object level permission.
- two for Indirect Read Permission for the Sales & Receivables Setup Tabledata (ID 311).
Now I have assigned these two role to user2. But user2 can not able to create the Sales Order. He is facing the below error message…
" You do not have the Read permission for the Sales & Receivables Setup table"
What is the reason behind this error message ? kindly explain if possible…
Thank you.
