Two part question, both probably very easy…
Used to be when we started AX Client, it would default to opening in Role Center every time. We changed EP servers, and now the client defaults to whatever menus were open when the client was last closed. How do we go back to starting up in Role Center?
How do you manually open Role Center in AX Client? We were able to get to it in the past because it was the first thing that came up. I assume there is a way to open it, as needed, from the client, right? (Without opening a web browser)
- Brad
