Hello
try to use axadmin there
same error when you tried to deploy without process?
which is this db : DAPCube Intial?
i can see you have two instances of the sql , please confirm it is not because of you are selecting wrong instance somewhere
Hello
Dear Mr. Kunal,
Same error without process also.
DAP is of thirdparty/vertical for HR here we use
Yes. i am using the correct instance sir.
Today: I removed SP and Analysis service , EP and reinstalled SP and now I have left for Full compile.
Once done I will install EP and Analysis service from AX setup.
Will update then.
regards
