RIM Toolkit
hi,
i started off by using the manual application but now i’m encountering a lot of errors because of the application setup I have to made… so do you suggest me to re-start off by using the RIM toolkit… my assignment is only to create a company…
thanks
when applying gl- question- answers the following error os being displayed:
The expression text cannot be type-converted to a Date value.
thnks
Hi.
What version are you using? Do you have the latest service pack for that version?
version 5.0
version 5.0 and service pack 1
RIM is quite sensitive. Best way to prepare a template is to do the export first then import. Ensure the formatting of the file is consistant.
i have the manual of the application setup so i’m following the exact steps…
If i have an Educational License do you think this is the problem, that i can’t change or modify data…?
thnks
There is a bug in 5.0 SP1 of data migration toolkit that means date fields will only get imported if you are using the USA date format of MM/DD/YYYY. The fix is quite straightforward but requires a developers license. You should contact your support partner if you are a normal company or Microsoft if you are a support partner to get the latest hot fixes to the data migration tool.
