Hi All ,
Is it not possible to create the RFQ when the purchase requisition is created withe procurement category only ?
( As we know that PR can be created against Procurement category and Item code is blank )
Share your thoughts .
Hi All ,
I would want a quote from my supplier against a specific item, if it was generic I would have a generic item for this, but it will give you issues when you order it later as you would then use a different item. I have no issue with this as it seems logical, but of course there will be businesses that want this, but then it is a customization.
Thanks Adam for reply ,
Why AX has the option Purchase requisition can be created against the procurement category ?
What would be business scenario to the purchase requisition against the Procurement category ?
Thanks in advance.
To allow end users who are not familiar with the exact item numbers to request a generic part, purchasing then define this into a real item through the requisition process.
Could you tell me at which stage and which document user can change generic to exact item number ?
Thanks in advance.
It will depend upon the requisition to purchase process of the business.
Thanks Adam,
Could you explain more about this ?
Not really because it depends upon you mapping the process your customer wants to what AX can do.
