Hi guys i make finished production order his quantity 30 and after it convert it from release to finish i realized that i write wrong quantity what i do to reverse this finished production order and how i will remove it cost from accounting
I create new order with consumption negative (it will show in item ledger entry positive) this i make already but the problem is when i go output then select order then write out put quantity by negative
