Is there any workaround to use in reuse check functionality for other countries (Not US , and CA)?
I find an articles that recommend to add the specific country we need from AOT → Tables → Bank Parameters → Allow reuse check (field) , and then add the country on country region codes (In the properties).
Does anybody have try this workaround? and what is the negative side for it?
and If you have other scenarios please share it with us
