I have a string like this:NL20INGB0007121497
And I just want to get the last nine characters of that string.
I try it like this:
MyString := CustomerBankAccount.Code;// (IBAN);
hallo := MyString2.GETSUBTEXT(SubText,1,STRLEN(MyString)-9);
MESSAGE(FORMAT(hallo));
where:
MyString= text
MyString2 = Bigtext
hallo = integer
Thank you
Raja123
February 16, 2016, 9:00am
2
hi,
Try This
MyString := ‘ANjdsuisf123456789’;
Evaluate(hallo,COPYSTR(MyString,STRLEN(MyString)-8,STRLEN(MyString));
Message(’%1’,hallo);
Small Suggestion Why You Want To Convert Or Store string Again into Number .
Avoid It let it be string/text is ok…if you convert and If first Number is Zero then it would Neglect zero…
Thank you. Very nice.
But I have it now like this:
CustomerBankAccount.Code := (IBAN) ; // FORMAT( CustomerBankAccount.IBAN);
// MyString := ‘ANjdsuisf123456789’;
EVALUATE(hallo,COPYSTR((IBAN),STRLEN( (IBAN))-8,STRLEN( (IBAN))));
MESSAGE(’%1’,hallo);
Because there is a datavase field CustomerBankAccount.Code
And the actual bank acoount number is from a XML file, with the propertie: IBAN. So the IBAN number has to be striped and goes in to the CustomerBankAccount.Code field.
But I get now the error:
Overflow tijdes typeconversie van Text naar Code: Waarde is:Nl41ingb0006618174
Ah, I have it now like this:
IF STRLEN(MyString) >= 9 THEN
MyString2 := COPYSTR(MyString,STRLEN(MyString)-8,9);
And it works like a charm!!
