I’m working in AX 2009 and also ssrs reports 2008.
How to return .net datatable from X++ code?
Any suggestions are much appreciated. Thank you.
You can use .NET Interop for that. An example:
public System.Data.DataTable getTable()
System.Data.DataTable dt = new System.Data.DataTable("My table");
System.Data.DataColumnCollection columns = dt.get_Columns();
System.Data.DataColumn idColumn;
idColumn = new System.Data.DataColumn("ID", System.Type::GetType("System.Int32"));
columns.Add(idColumn);
return dt;
Hi Martin,
Thanks for your response its worked for me.
Hi Martin ,
Thanks Its worked for me. I have another problem.
After deploying my report to SSRS its throwing error like CLRObject not initiated . because i am returning .Net Data Table.
Pls Suggest me the Solution,
