Return Item in Project
I have been doing a test for returning items which already shipped in item journal of project module. The problem is that it should input return cost manually. I would like to input it automatically by tracing its return LOT Id. When I tested in movement journal of inventory, it works.
Is there any way to deal with it?
Best regards
I am not clear on “where” you are doing this, but have you looked at marking?
I am doing this on Project management and accounting/Journals/Item.
I did a test using makring as you said, and it works.
Thank you so much for helping me always.
