Retrieving Value From one Page Field to Another table Field
Hi Experts,
I have a requirement of retrieving value from a field called Applied Amount to Payment Journal Lines.
its like if we going to pay a vendor some money , we have to apply the Open Invoice ,right?
we we click the set applies - id it will apply the selected lines. there will calculation of ‘APPLIED AMOUNT’ at the end of the page.
i want to get this value to show in the PAYMENT JOURNAL LINE RELATED TO THE VENDOR.
it would be great if i got some advice and example.
To retrieve the value from the Applied Amount field in Payment Journal Lines related to a vendor, you can use X++ code to fetch the value and store it in a variable. Here’s an example code snippet:
VendTable vendTable;
PaymentJournalTable paymentJournalTable;
PaymentJournalLine paymentJournalLine;
Real appliedAmount;
select vendTable where vendTable.AccountNum == ‘Vendor Account Number’;
select paymentJournalTable where paymentJournalTable.VendAccount == vendTable.AccountNum;
select paymentJournalLine where paymentJournalLine.JournalNum == paymentJournalTable.JournalNum;
// Loop through payment journal lines related to the vendor and fetch the applied amount value
while select paymentJournalLine where paymentJournalLine.JournalNum == paymentJournalTable.JournalNum
appliedAmount = paymentJournalLine.AppliedAmount;
// Use the appliedAmount variable to show the value in the payment journal line related to the vendor
You can modify this code snippet as per your requirement and use it to retrieve the value from the Applied Amount field in Payment Journal Lines related to a vendor.
