Hi
How to restirct one of client comuter to access AOS.
Scenario is as
I have two instance of AOS.
My exact requirement is that user can not access one instance of AOS on a specific computer either it is login as admin or any other users.
Hi
Scenario is as
Hi Reyaz,
In the client configuration utility, mention ONLY the AOS that client has to connect.
Best wishes,
Hi Harish,
Thank you for reply
Apart from this is there any other solution because user can change AOS name in client configuratioin utility.
HI
Is it possible to manage any rule to restrict users by computer name at server end.
I think that this doesn’t work if load balancing is set up. In that case, the client configuration is ignored.
HI
I think it can be done by creating a customization. From what I remember, there is a function to block new clients from connecting to the AOS (it should be on the Online users form). If You figure out how that works, it shouldn’t be a problem to add a new feature to block not all new clients but only those that You specify (e.g. in a separate table).
Lukens
