I am upgrading old customized Navision DB(3.60) to new DB(3.60),as a part of R&D for our new Project. But in Upgrade Tollkit pdf, it has been given tht… “Restore the objects from the backup of the old customized Navision Financials database into new version of Navision. Do not restore the data now.” So I want to know, how to restore only objects without data. Even I unchecked the “data common to all companies” in Restore window. but still data is imported. Thanks in advance… vikas
In object designer, choose File->“Import…”, then select the fbk (sic!) file as import source. This will import the objects from the backup file without importing the data.
Thank You Sir…[:)]
