I’m not sure if this is the correct area to post my question but here it goes.
I have Navision 2.60B (3.60) and I was in the Object Designer to modify one of our reports to print in landscape format so I clicked to copy the report so I could play with the copy and when I went to paste it into the report list the original version vanished and the copy never pasted either. Is there a way to get a backup of the report?
This is exactly why you should do development in a separate development/test database, never the production database.
Use your latest full backup to create such a development database, export the object from the new database and import the object into the other one.
Next time you want to take a copy of an object, you open the object in design, and you select “Save As” from the file menu. It will ask you for a new number and name, and it will leave the original object intact.
