Restict the specific users from using the Zoom (CTRL+F8)
How do we restrict the users from using TOOLS → ZOOM
Thanks in Advance
Set them up with the appropriate roles. There is a System permission for Zoom.
I want to Use this one only for a specific table not for all tables.
Thanks in advance.
You can try by creating a function in form and Set Short cut as Ctrl+F8
Also set visible no for that function
It works only when user is using shortcut…
try this
http://dynamicsuser.net/forums/p/9408/32318.aspx#32318
Hi David,
What is the Function RunforcheeckF8(Caption ref)?
That’s the custom function you need to write to check if that user should have access to the data
