responsibility center in Ax 2009
Is the any concept of responsibility center in Ax 2009 as it is in Navision. ???
Which menu option are you seeing this under in AX2009?
From my dim and distant past I remember in NAV that these were used as a centralized ordering repository, so it would default in where the order should be fulfilled from or delivered to etc. In AX this would be the site. Different concepts but different software offerings.
