Client had 2009 now moved to SP1. But after installing SP1 whenever we are closing the NAV it gives message you do not have permission to run codeunit EP Request handler.
I went to this codeunit found one record type variable EP Appln Setup , found a record there surprising because my client has nothing to do with Employee portal. But i though clearing this record will get me rid of this message but no avail. Has anybody faced this issue ?
are you saying that this error message appears when any user tries to logout or exit NAV?
Sounds like it could be running through some erroneous code in the close company in Codeunit 1. I’ll jump to a machine with SP1 installed and take a look.
OK - had a quick look and the CompanyClose() trigger has a EmployeePortalApplSrv.StopQueue; function call. I’m guessing there should be some code in there that does not try to run that if you don’t have the EP granual. A quick fix would be to comment that line of code.
Anyone know the proper way of avoiding this based upon the license of the current session?
the Employee Portal granule is “A La Carte” in the price list meaning, it is not included in BRL BE unless it is separately ordered. Of course you could have ordered this and it just got missed off by the licensing people. But I’m wondering - is there still a problem in the code. You shouldn’t be getting error messages by trying to logout just because you don’t have a granule.
I woul think that there should be some kind of permissions check in there before trying to run the codeunit.
Please update the post when you find out to let us know whether it is after all a licensing issue.
