Hi everyone,
I’m attempting to close a Kanban using code, so after debugging the process manually and changing one method ( KanbanMultiJob::newParameters() ) from protected to public, here’s the job I could come up with :
static void testKanbanJobCompletion(Args _args)
KanbanMultiJobComplete kanbanMultiJobComplete;
KanbanMultiJob kanbanMultiJob;
KanbanJob kanbanJob;
KanbanBoardTmpProcessJob kanbanBoard;
container kanbanCon;
Common common;
_args = new Args();
kanbanJob = KanbanJob::findByKanbanId("019418"); //card 005264
kanbanBoard.init(kanbanJob.wrkCtrResourceGroup().RecId,3,250,250,250);
select * from kanbanBoard where kanbanBoard.Kanban == kanbanJob.Kanban;
info(strFmt("Selected Kanban %1 Card Id %2 from kanbanBoard...",Kanban::find(kanbanBoard.Kanban).KanbanId,Kanban::find(kanbanBoard.Kanban).KanbanCardId));
common = kanbanBoard;
kanbanCon = [common];
kanbanMultiJob = kanbanMultiJob::newArgs(_args,
LeanKanbanJobStatus::Completed,
false,
kanbanCon);
try
kanbanMultiJob.runMain(_args);
catch
info(strFmt("Error while ending Kanban n° %1.",Kanban::find(kanbanBoard.Kanban).KanbanId);
info("End of treatment!");
When I debug it, it does exactly the same treatment as manually clicking on “End” in the KanbanBoard, the only difference is there’s no form. So if anyone has any idea or lead, or has already crossed this kind of preoblem I’d be grateful.
Thank you!!
