Narration has 3 lines ,when we print it into report it is directly showing 3rd line ,how to print the first line of narration.
please provide the solution.
In which report?
Base or Customized?
What did you try?
can you please tell me the diff b/w base and customized report.
Base reports means the report which comes with initital database.
Customized report means you have done some modifications as per your requirement…
What is the report ID?
it is customized report…and one more thing that when i execute report the serial no column is not in sequence numbers it is jumping y?
Is it possible for you to show the screenshot of the reports?
why because your code logic is wrong
The code will execure exactly what you have written
