reports
HI All,
HOw exacly could we create complex reports using dynamicss AX???
I think that this question is too much generic to have a clear answer…
What means “complex reports”? If is a problem of selecting data, you have to override the method fetch to obtain the correct selection of data (take a look, by example, to SalesInvoice report), if it’s a problem of print layouts, you have to modify the design section of report.
Is “get trained and gain experience on simple reports and then move onto complex reports” the answer you want?
