Guys i am facing big problem in reports i.e when i am running the reports on my local machine then it is coming correctly with all calculated values but when i am uploading same reports object on server then running it does not show the calculated values and in some other reports design also gets disturbed.
Which NAV Ver ?
How have you uploaded the report & from where ?
NAv 2013
by export n import.
From local machine to server
Check by restarting the NAV service on the server.
