hi all,
Is it possible to converse a report into a pdf format?.
Thanks.
hi all,
Thanks.
There are many options for PDF creators that act like printers converting documents to PDF format. Most are even free to download. Simply choose the PDF creator instead of a physical printer when printing the report.
www.primo****pdf.com
Primo PDF is the free tool we use to ‘print’ to pdf files. It will install as a printer. Then when you print to it, it will ask you to create a pdf file.
thanks both, decept1 and AMPPI for your answers.
Best regards.
cutePDF works the same way: http://www.cutepdf.com/products/cutepdf/Writer.asp
