I have one issue regarding to Reports and Pages run RTC. The situation is as follow:
Nav Datbase is upgrade from the Nav 4.00 to Nav2009r2. When I run Tables,Forms,Reports on Classic Client site there working fine.
On the RTC Pages and Report shows an Error. The Error message is -
Microsoft Dynamics NAV
The server “net.tcp://localhost:7046/DynamicsNAV/Service” is either unavailable or your connection has been lost. Do you want to attempt to reconnect?
Yes No
After Click to Yes It shows message ---------------------------
The connection to the server has been lost. The application will close.
OK
I am Try some Solution for that condition.
1.Restart the service Microsoft Dynamics Nav Server
2.Delete the profile id in the User Personalization table.
**3.**Assign Super Role Log In from Different User.
4.Check default T****CP\IP
I recollect the above solutions at that moment But they are not working.So there is any solution regarding the problem. Your Reply are are very helpful.
Thanks & Regards,
A.V.Yadav
