Hey there,
I’m using NAV 2015 in version 8.0.39368 and I have a problem regarding the IncludeCaption Property in the Report Dataset Designer.
I have done some calculation and stored the results in a buffer table (called statistics).
With an Integer Dataitem i want to iterate over all entries of the buffer table, that’s why i have all of statistics (it’s a record variable) columns indented under the integer.
I set the IncludeCaption Property to yes.
In the RDLC Layout i used drag and drop to put the captions into a table (the value is e.G. =Parameters!Contact_NameCaption.Value)
I have filled the multilanguage caption in the buffer table with ENU and DEU captions which are the languages i have installed to my NAV.
I have also tried to fill the multilanguage captions of the columns in the report.
Even if i filled both, all I get in the print preview is the name of the column with an appended “Caption”. e.G. “Contact_NameCaption”
I have tried to use the label Manager and that worked fine.
Why does includeCaption not work in this case?
