hi all
I am trying to install reporting extension. When I run the Setup, I get the following message : “You must install SQL server 2005 Reporting Services Pack 2 before installing the report extensions”.
but am using sql server 2008
wat s the pblm
pls anyone help me
thanx in advance…
Hi Please read the document for installing AX 2009 SP1, you will find the solution
Thanks & Regards
Rajesh
hi any one pls suggest some other ideas
thanx in advance
Hii,
after u extract the hotfix(DynamicsAX2009-KB957312-v3)u ll find in setup one .dll file (microsoft.dynamics.reportingservices.dll)…copy this and paste it in your ax2009–>msi–>components64–>program files–>microsoft dynamicsAX–>50–>setup …thats it again try installing ur reporting extensions u ll get it
