suggest me a solution…how can we copy company to company
That depends on which version of Navision you are using and if this something you’re planning to do once as part of your initial implementation or if it’s more a synchronization between two companies.
iam using microsft dynamics r2.can i create two companies and copy the data
Go to Administration → IT Administration → General Setup → Setup Checklist.
Here you can setup which tables you want to copy and use the function “Copy Data”.
This is part of NAV’s RIM tool.
thank u…
Prasamsa,
As a new member you are most likely not familiar with the rule here on DUG that you should always select “Verify Solution” on the post(s) that solved your problem. This credits the members who helped, earns you points and marks your thread as Resolved so we all know you have been helped.
ok
Hi Prasamsa,
Thank you for verifying my post, but I have removed this verification, as you should “Verify” the post that really helped you solve your problem. Not my reply asking you to verify the answer! [:)]
ok thats fine…thanks for telling me that
i got the answer…thank u
