Report Standard Purchase order is showing blank while opening with report builder.
so, I am requesting to you can anyone help me with this or provide me 1322 standard report to me with rdlc format only.
I was using by report extension but it was showing blank.
Hi @Shiva_Krishna,
You can do it yourself.
After you have downloaded symbols in Visual Studio Code you can uncompress the “Microsoft_Base Application_x.x.x.x.app” (you can use 7zip for this) and you will have a directory structure where you can find the “layout” folder and there you will find all RDL files from standard reports. Before you can get rdl file, you have to check for RDL name in the report object.
