Hi all
I want to count the Number of records (Printed Lines) on a certain Body section of my report and display the total value on the report.
How do i manage this?
Thanx
Hi all
Thanx
Try this:
Define a global variable eg.NoOfRecords, then OnPreReport(), include
NoOfRecords := COUNT()
Display as footer
COUNT in OnPreReport will count all records within initial filter before the output.
Although this [probably] will not work in the upcomming NAV “>5.0”, the current solution is an INTEGER-variable and an adding to the variable in the OnPreSection (inCounter += 1;).
