Are you sure there is no error message? Usually the information about where to find more information is added after at least some information.
What exactly happens? When did it start happening? Is it a customized report?
If you wan to enable remote errors, just search the internet and you’ll find the documentation.
Thanks Martin, The only error message is" For more information about this error navigate to the report server on the local server machine, or enable remote errors", clicked on it, then jumped to Form\SrsReportViewer\method\AxReportViewer_RefreshComplete.
Just run a standard report, not customization, only a report does not work, have tried to restart AOS, did not help
Hi Kunal and Martin, I went to the report manager url and found the report, directly run it in browser, so I got this error message: An error has occurred during report processing. (rsProcessingAborted)
Query execution failed for dataset ‘Dataset1’. (rsErrorExecutingCommand)
For more information about this error navigate to the report server on the local server machine, or enable remote errors.
Any ideas?
