Report Header Cust Address Goes Blank.
Dear Experts
When i run report ID 116, “Statement” and print a pdf, it shows perfect data. But when i call this similar report from an another report and save as pdf at run time and mail it to the given mail ids, the customer address in the header part goes missing apart from only some partial information. I checked almost all the possibilities rt from the parameters being forwarded from this new report to 116 the original one and also the report layout.
What might be the reason behind ?Need Your help !
Version : Nav 2013
The textbox is hidden in header (code.setdata) needs to be first thing that activated when the report is rendered. Also add move Code.Setdata expression to Hidden property of the text box.
Thank You so much ! Its working now.
Regards
Gaurav Singh
