report designer
Hi everyone,
i need to create a new report in dynamics nav 2017,i installed vs 2017 and report designer 2017 but i get an error message when i open report Layout:
Looking forward from your help.
thx.
Hi Karim,
Did you install it including the Microsoft Rdlc Report Designer for Visual Studio?
You need below one of the versions of Visual studio with respective .NET framework to work. I also had the same issue and I installed Visual studio 2017 with .net framework 4.7 and it worked.
Codename
Visual Studio 2017 Dev15 Supported .NET Framework versions 3.5 – 4.7
Visual Studio 2015 Dev14 Supported .NET Framework versions 2.0 – 4.6
Hi Erik,
Yes i did,i installed VS 2017 and then Rdlc separately.
thanks.
