Replace dataport communication
Hi i’m dealing with 3 databases 1.) nav 2.01 ERP native DB 2.) nav 2.60 Lohn native DB 3.) nav 2.60 Gehalt native DB I use dataports to change data between the 3 databases. Is there a more comfortable way ?
MAybe ODBC Drivers can help you, but then you have to synchronize data exchange outside of navision with a scheduled application. (for ex. SQL server DTS) Otherwise, if you can port all of your Companies in a single Nav DB you can copy data between companies with a codeunit or a report, without the need to export files.
