I want to know the functionality of reorder policy in item card (planning tab). If i set reordering policy as Fixed Reorder Quantity and enter the Maximum Order Quantity as 100. What will happen when i run planning worksheet and requisition worksheet.
Can anyone explain the whole scenario of Reordering Policy Concepts.
No this is not possible in my experience. The demand will ultimately override the order modifiers, you need it to the final step is to adjust the requirement. I have not tried this in AX2009, so you may want to. I would also advise you use the search function on this forum, reordering policies and issues with have been discussed many times over the years.
