reopened delivered(closed) sales order
how we can reopen closed remain itemes in sales order ?
what do you mean under “closed”? Do you want to create a new order from posted sales order or create correction document (e.g. return order)?
actully i have posted packing slip and checked close checkbox for rimaining items but i found that made a mistake and i want to have ability to send remaining itemsis ot possible to reopen sales order for sending remaining items
Based on your phrase I may imagine you use Inventory pick, right? Or you use Addon|Extension something like LS (because it is a slip and “checked close checkbox for rimaining items”).
Could you write more (include installed NAV and addons) to help us to help you?
in order to set sales order firstly i creat new order then make picking list after that post packing slip.the isuee is in posting packing slip step when i want to post less than initiall quantity considered in sales order i check the close checkbox for cancelling remaining items but i want to now how i can chang status of line from closed to open in order to send remaining items again.
To be honest, I don’t know what is “packing slip” & “posting packing slip step”, but “Inventory pick” and “sales shipment” => it is hard to help you.
For standard warehouse functionality we can use “Register”-term => you can use AddOn|Extension.
If we use standard functionality (“Inventory pick” and “sales shipment”) you need to correct quantity in the “sales shipment” and ship. for the rest of the goods, you need to create Inventory put-away and register it in the correct bin.
Tanks a lot .it was helpful answer but not exactly what I wanted to know however the problem solved.
the problem was sending remaining item for customer while we closed sales order before.Not store the remaining Item in warehouse and bins after shipping.
Ok, it is very good. But what was the issue - you need to create new Warehouse Shipment Doc => create and register the Warehouse|Inventory Pick => post warehouse Shipment
