What is the use of renumbering tool in navision 2013 r2 . Any one please explain simply
You use it to renumber objects.
Lets say that you have create a customization for a customer in the object range 50000-50009. Now you want to use this customization for another customer. But this customer is already using the same range. Then you can use the tool to renumber the objects “automatically”. Here the tool also finds and change all the references to the object. If you just changed the actual object number, then you would have to do it “manually” from the text version of the objects, which if your customization is big, would take a lot of time (search and replace).
Check out this link
Thanks.
You’re welcome. If it helped you, then please click on the “This helped me” on the post. Thanks.
