Hello All,
I want to rename the field name from VAT to GST from all forms,reports,tables.
So, Is there any tool for that. Please help me.
Chetan
Hello All,
Chetan
Hi Chetan,
There is no tool…
You have to do manually
Ashok…
Have you tried to rename the caption property of the field ?
Is GST Launched ???
Change the caption of the field wherever you required manually
Manish & Amol i want that change on all forms,reports, tables, ETC
Manish GST is not launched
If yopu change the caption of field in table level then it will change in most of the places of forms and reports unless you have hard coded it,
Ok All of you
Thanks for Reply I ll try it
Chetan
Change the Caption from VAT to GST in the field property in table should do the trick.
Yes GST will be launched in 2013…2014…2015…??? [8-|]
2030 …[;)]
[Y]
Hi Chetan,
I saw a forum mentioned about this issue as well and there is suggestion to install other language in order to solve this problem but the solution is not verified yet.
Here is the link to the forum:
http://www.mibuso.com/forum/viewtopic.php?f=23&t=15124
I am currently facing the same issue too and might be trying the solution suggested in that link. If you have a better solution, can you share it around? Thanks.
